Check the timming again. The belt could have jumped. Sounds just like my car when I did a rebuild last year.
Do this for me please. Remove the cap to the distributor, and spin the rotor Does it spin freely? As in if you where to spin it in one direction then back in the other direction freely?
Are all your 15 fuses in good condition? Just between the battery, in the box thiers a 15 fuse in the lower right corner its the main fuse for the ecu if that fuse is out or bad it wont start also.
These two problems will also produce the same effect.
