NA to Turbo without a swap?
M
Makavelli
Guest
How much RWHP could I realistically expect from a bolt on Turbo?
M
Makavelli
Guest
IJ. said:
Ummm I did say on a bigger better flowing Turbo NOT on a CT!
Some of the guys will jump in with what a CT will make at 12 psi but my guess is it might make around a 50% increase in power from your old NA if everythings done right!
Most of what you're doing is just a bolt in so difficulty isn't high, Hardest part is sorting the Turbo Drain as the NA block isn't drilled and tapped for it.
How hard is it to sort the turbo drain?
