Na-t?
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
With 180,000 miles on my odometer, is it safe considering a NA-T project? I'd like a bit more power, but I'm not sure if it'd be more worthwhile to swap an entire engine.
The way I figure, it would be around 2k for a total 7m swap and around 3k for a 1jz. Has anyone turboed their NA and still has their parts list/cost list around?
s383mmber1
3,614
Somers New York
Well this is simply an opionative question but it more of "How much money do you want to spend"
Ive been researching na-t swaps for quite a long time now and ive learned its much better to go through a full engine swap. Either that or re-build the current engine in the car for turbo.
And were are you finding 1jz swaps for 3g's?
Clip
Oct 16, 2005
2,738
9
Virginia
ive heard that the gte is a whole different beast, with the devil in the details such as the oil squirters and compression ratio, cooling fan and so forth. as for the 1jz swaps, front clips from driftmotion are $2600 and from jarco with the 5 speed and lsd its maybe $2995. are those prices incorrect?
92turbo4life
1,289
wherever
noope.. osakajdmmotors.com has them for
7mge-400usd$
7mgte- engine only 700 usd$
1JZGTTE -2.5L Twin Turbo A/T- 800 usd$
2JZGTTE 3.0L Twin Turbo A/T - 1900 usd$
2JZGTTE 6SP 3.0L Twin Turbo 6SP- 5500 usd $
so i thiunk that would be ok.... osaka mtors have 30'000 to 70'000 miles on them when i called:)
daledoe
KILL U
Nov 18, 2005
1,467
MAINE
I'm in the middle of puting a 7MGTE in a NA chassis. I've spent like $3000 already but the motor is not going to be stock when it gos in. Some of that money was spent on other stuff like brakes, stanless steal lines, exhaust, ect.
daledoe
KILL U
Nov 18, 2005
1,467
MAINE
7mge-400usd$
I got my motor at osaka and there great!!!!! Good service and it was quick as hell getting to me. Like 1.5/ 2 weeks, something like that.
daledoe
KILL U
Nov 18, 2005
1,467
MAINE
I was thinking the same thing???? I got my motor 2.5 years ago and I've never seen front clips on there usless I misted it???
1TuffSupra
Sho' Nuff
500
Raleigh, North Carolina, United States
I am currently doing the NA-T conversion to my car. I would say that with that many miles on your car you should definitely consider rebuilding it or, like me, get a jdm motor. But if you still want to consider using the motor you already have then do a compression test and post your #s up here and ask your question again. But I have a list that I found on supraforums that I have been using to build mine. Ive added some things, removed some others but these are some of the prices u should expect to pay. Mind you this is a 1/2 NA-T since Im keeping my NA electronics.
Mechanical:
Headgasket - Cometic 2mm 935motorsports.com 169.00
ARP Headbolts 99.00
Turbo - stock ct26
Oil Lines - Rabidchimp.com CT-26 Oil Lines: 125.00
Coolant lines - already there
intercooler - stock intercooler 50-60.00
intercooler piping - Intercooler and Lower Piping: 80.00
Upper IC(CRX COLD AIR INTAKE(2)) 86.00
downpipe - Because i can DDP bicperformance.com
intake piping - stock Accordian Hose or piping from ic piping
Exhaust manifold - stock purchased 90.00 shipped
Blow Off Valve - HKS
Misc - Adpaters for Oil Return: 45.00
Intercooler Couplers and T-bolts: 100.00
Gaskets 100.00
Catch Can: 43.00
Fan Shroud:78.00
Boost Gauge: 63.00
EGT Gauge:
Air/Fuel ratio Gauge:
Oil cooler and Intercooler brackets
PCV/ISC hard and soft lines
Power Steering Reservoir and lines
Oil Cooler
GTE oil pump
Fuel:
Injectors - 440cc Injectors: 60.00
FPR - Stock Turbo FPR: 15.00
SAFC
