NA-t finished!!!
JT87NA
SLC, UT
tubbie said:
I'm using the NA intake on my na-t. A friend of mine has the exact same setup as me, except his car is a turbo car and he has a 3 inch intercooler with hardpipes. We dynoed one after the other at 18psi. I dynoed 368 and he dynoed 358 on the same day. Was it the NA intake? I don't know.... Just food for thought. :biglaugh:
Are you using 7MGE pistons with a cr of 9.2:1?
iceberg319
vvti, what?
Apr 6, 2005
328
NJ
what are your mods???
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
Using turbo block and pistons, but milled head and block with HKS 1.2mm hg. I'm guessing that should put me around 9+ compression ratio.
All stock motor with ge intake manifold
ct26-60
stock intercooler
lower intercooler hard pipe
vpc, afc -untuned
3 inch elbow, downpipe, no cats, kakimoto 3.25 exhaust
Here is a pic of my engine...
and future mod.. next spring.. :evil2:
jnianekeo
128
Mill Creek, WA
Nice CAr! I'm inspired by your work. Im doing an NA-t conversion and I was wondering if you can answer a couple questions i have....
I wanna keep the stock GE electronics for now...cuz i have no money...
Can i keep the stock 315?cc injectors? I'm only lookin to run 6-9psi at most..
Do I need to get a rising rate fuel pressure regulator? SAFC? ANything else?
Sorry to nag you, but I'm desperate for help right now.
THanks!!!
dragracer
GearHead
Oct 31, 2005
221
Churubusco
Finally, a statement made with some type of proof. More than likely its the intake. Could be your friends IC piping (3 inch might be hurting some if using stock ct-26) making the difference. Just a thought.
What turbo's are you guys running?
What rpms was each of your hp numbers?
Nice car!
dragracer
GearHead
Oct 31, 2005
221
Churubusco
iceberg319 said:
is it not gonna last long :(...any idea on how much boost i can run???
Still running GE pistons? The higher boost you run, the higher the compression ratio results in. So starting out with a higher compression will be a factor. Just make sure there is enough fuel there.
Have fun and Black MKIII's are the BEST!!!!:icon_conf
