NA Pistons in a Turbo
Justin
Speakers?
Spokane, Wa
How many people have done this?
Turbo: 8.4
N/A : 9.2
I have NA pistons that only have 10K miles on 'em so I would imagine they're in good shape (stock NA)
I'm rebuilding a JDM GTE with a MHG and ARPs
The benifits that I've heard is a faster spool and more power... what are the downfalls to doing this?
Justin
Speakers?
Spokane, Wa
Supra Blues said:
Yeah, you'd have to be careful with that setup. I don't think you'd be able to boost as much with NA pistons vs T pistons.
Definatly would have to be carefull, but would the added compression compensate for the lack of boost?
Supra Blues
Virgin Booster
Supramania
Dunno, you'd have to ask one of the N/A-T guys around here.
I've been told its really only safe to run about 3-5 psi of boost on the na pistons.
boost PSSH boost
SM's Welding Guru
Apr 4, 2005
465
Marshall, WI
A local guy was running 11psi on his 1/2 NA-T...only problems he had were the stock HG and his clutch that coudn't handle the torque.
His car could pull mine on the highway, and I had a bigger turbo, upgraded fuel+ lexus afm...full 3" exhaust, intake...he had safc, intake, upper hardpipe, and 2.5" exhaust at the time, only running 9 psi...compression makes a big difference.
Justin
Speakers?
Spokane, Wa
its stories like this that make me want to go that route
I'm going with full 3" all the way back, and eventually a FFI with all the nessesary fuel mods.
Darkcyde
Workin' Man
La Villa Strangiato
A friend of mine is running 12psi on his NA-T for 6 mo. without problems so far.
He just ran a 13.117 with turbo-back custom exhaust, lex afm, hardpipes, K&N, and G-Force drag radials.
SupraMario
I think it was the google
The Farm
well 8-9psi safely, NA pistons are bigger, so i dont know how ur going to get them into the turbo motor, i would be very afraid of detination if you go over 10psi. and they say the 8-9psi on an NA is like boosting 13-14psi on a turbo motor.
7MGTEJoe
Salinas, CA
WTF? The NA and turbo engine have identical bores.
I believe John Lunsford is running 9:1 JE pistons. You really should talk with him about how that works in a 7M.
In general, increasing compression is exchanging potential mid range and peak power for more torque off boost and some improvement in spool up.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
I agree with Joe.
You gain low end torque, and spool is faster.
You lose potential top end... so you're never going to build a 900rwhp monster with NA pistons unless you mount a head spacer to drop your compression again.
John Lunsford is absolutely running high compression pistons, see if you can get some info from him - or from his 7M Power page. :)
Supra Blues
Virgin Booster
Supramania
Okay, I guess you can run more the 3-5 psi.
Take a look at what other mods those guys have that are running in the 8-15 psi range though.
I could just be :blah: :blah: though.
Good luck man.
Justin
Speakers?
Spokane, Wa
No 550's, just a lex? Are those the only relivent mods?
Thanks, I'll see if I can get ahold of him
hehe, you could have just stated I was never going to build 900rwhp and put a period after it. I doubt i'll ever get over 400 if that... unless I get a job where I can afford that much power :)
Thanks for all the help guys, this is exactly what I was looking for.
My plans are just to build the eingine using all ARP hardware, a MHG, possiably a BIC DDP, definatly a full 3" downpipe, and an apexi power intake for now.
after I build my savings account back up I was going to do emanage/550's/some type of air flow mod
What would I use to make sure that all was running well if I were to go this route? I'm definatly getting a wideband but I was hopnig on putting that off till i started adding more mods.
Would there be anything else I needed to do or just put in the pistons, run the stock boost of ~8-9 PSI with intake/exhaust
NATAN666
yarrrrr
Apr 4, 2005
289
BC
user.dccnet.com
if i were to run NA pistons in my turbo motor, would i need na rods too? im new to engine building so im not entirely positive on the basics. na pistons in a turbo motor wouldnt affect stroke or displacement correct? just compression?
TONY!
Habitual Supra Killer
Tonyland
I have discussed raising my compression with a bunch of members at one time in the chat room (GrimJack, Suprra_Girl, drjonez, sponsored1, projectsupra) since many months ago. Suprra_Girl has high compression pistons in her 7M-GTE.
Sammydafish is the one that got me thinking about raising compression in the first place. He once told me that just by doing that you can get a very noticable increase in power (it was a reply to a PM of mine that I sent him to say, "hi you must be not too far from me" kind of thing since we are both in Upstate NY). And I have been thinking of what he has said since.
I imagine you would have slighly better gas mileage (a feature of high compression motors).
You would also get more power ("free") since that is also a feature of high compression motors (unless you are sacrificing boost).
I have also been thinking of using N/A pistons because if the N/As can be turbocharged with their pistons (assuming they use their original pistons), why can't I.
I don't plan on going hi psi (figured like 10psi max), and I also don't plan on making a race machine, I just figured more power and slightly better gas mileage--how can you beat that?
My intended set-up may be different than yours though, Justin. I am only building very close to stock (my need for speed only gets quenched on 2 wheels).
Paging Suprra_Girl to this thread. hehe
