NA Nitrous?
gofastgeorge
944
Texas
If you keep the shot at low levels,
say, 150 max,
then the stock rods & crank will be fine.
But I would also do ARP rod bolts.
Jens Lyn
95
Denmark
Heyyyy...
I see a lot off talking.....but no pic yet :).
Lets change it;-).
I had a 150hp+ wet nos system, at my celica supra 5mge(2.8) on the standard block.
Didnt do any other modifications, just mounted the system and then played with it.
It wasn´t made finish, so that is why you see all the wirring and stuff.
I tell you.....it was DAMM fast 0-180Km/t was done Xtreme fast. :)
And if i launched it at 160KM/t (100mph) it made the rear wheels spinning.
It sounded like an jet plan........weeeeeeeeccc 3 gear.....weeeeecccc 180km/t....and then brake like a mad man cause the road wasnt longer he he.
I would like to mount a kit once again, but first when the engine is used a little.
It was made with extra fuelpump only for the nos system and with its own pipeline to the tank.
I also made an purge valve, damm it looked nice when purging :)
Picture Host - PicTiger
Jus10dun
Springhill,FL
Reply to: Jens Lyn
Looks Bad Ass!!
Do you ever have any problems woth leaks from you lines running from the blocks to the nozzles? I understand the when you put them in it just snaps in.
I am planning on running stainlessteel lines for reliability. The las thing i need is a fuel leak.
What octane fuel do you run? Timing retarder? Pistons?
