N/A-T question.
AJ'S 88NA
2,419
Florida
Ma70.Ent;938748 said:
My brother _had_ it. He gave it to me because he changed his setup, plus, hes turbo now :p
Anyways, let's see if anyone else has some input on this. I want to know if I can use the SAFC I got for free or not :D
I had one on my GE worked fine. The only thing was I had to have it tuned at the Dyno as they had a WB to tune it. I sold it to a member with a GTE. Only thing I would have added is a WB so I could tune it myself.
Ma70.Ent
1,871
NJ
You tuned it on your GE with no problems? Did you get gains or what? :D
I have a wideband of my own, so tuning is no problem, I just need to know if it will work or not.
Once again, jong, the originator of the 1/2NA-T tuned his car with an SAFC too. So yeah..we need to hear Degree's dad's explanation.
DegreE
500
Memphis & Miami
Typical AFM on most cars read the signal from 0 to 5 volts.
The GE AFM with the flap, reads from 5 to 0. Therefore the SAFC reads the signal, its completely backwards and throws everything off.
AJ'S 88NA
2,419
Florida
Gains??? Hell yeah!!! But maybe the 60 over, 10.5-1, cams, stroker, and everything else may have helped a little too:)
The reason I installed the SAFC II was I couldn't get the car to run decient with out some sort of control. Like I said I would have liked to had a WB to tune it myself. Now I have a WB with Maft-Pro and I can tune it myself.
I don't know why they are saying it can't be done on a NA. The ECU pinouts the instructions give you suck. But with a little research it wasn't to bad to wire, easier than the Maft-Pro.
You should be able to gain some from it for the simple fact(I'm a simple kind of guy CRE will testify to that) you can fine tune a little better to take advantage of any mods you make on the car.
iceberg319
vvti, what?
Apr 6, 2005
328
NJ
Chambers;938662 said:
Thank you, lol.
I have a NA-T in the works as well, I'm trying to stay away from GTE electronics for as long as I can. I have everything ready besides BOV and fuel computer. Good luck on your projects.
why would you stay away from GTE electronics....imo that would be the worse thing to do if u plan on running @ anything higher than stock boost. unless your planning to use standalone or atleast a maftpro good luck b/c ge electronics have no maps for boost.
fyi ive been running my car for the past 3-4 years on this setup@13-14psi and have had zero problems. from what ive seen the ppl who havnt switched have blown motors and usually arent NA-t anymore.
bluedragon17
87 NA-T baby!!!
Sep 14, 2006
382
Vacaville, CA
Im running on N/A-T currently i got a turbo t-stat housing(the one that attches to the head) becuase it was tapped and has a fittingfor the turbo lines. As for the feed you just need the turbo feed line fitting. I got a bunch of parts from a turbo car and it made my swap so much easier. Also i recommend getting the softline kits from Driftmotion for the GE motor made install almost painless on my part. Ill try to post pics of my setup(more specifically the fittings above).
Sl1dewaysSupra
Destroyer of FWD's
Mar 14, 2006
690
Colorado
I was thinking of going that route myself. Im going to take a look at the banjos next time I get under the car and decide from there. Thanks for the input guys.
