N/A Powerband
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
Hey all, I wanted to know where the powerband is on you're cars. My n/a is auto and bone stock, but it seems like it's powerband is in the higher rpms. I get great acceleration off of the line, but the RPM's fall off a little if I'm not WOT.
Here's how it works for me: Say I'm at half throttle. If I'm accelerating, the RPMs will go to about 3000, then drop to 2700-2800, then climb to the top before shifting. It seems like all of my power is up top.
Is this normal for an n/a, or would this be like if the previous owner tossed a gte intake cam in?
(I know my wording may be a little confusing, and I apologize for that.)
Thanks for any input
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
sounds like your transmission is downshifting when you step on it, which is what it's supposed to do..
there's a "kick down" button on your gas pedal that causes it to shift..
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
What?
If you're rpms ever go down while accelerating you have issues much larger than a turbo intake cam.
I think you miss-worded that.
The N/A's seem to have most torque around 3-4,500 RPM. That's just a guess on my part, but I do recall peak torque coming in around there.
**Edit, RazoE's idea might be what you're talking about, but I still dont understand what you are saying about your rpms.
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
I probably did word it wrong. I'll try to get a video up by tonight to show what I mean.
Razoe: It does this in first gear as well.
Ma70.Ent
1,871
NJ
Post up a video. Your post was confusing.
Although my N/A's powerband was everywhere, the "strongest point" of my car was around 3500+ RPMs. I never felt a "V-Tec" like kick in my car, ever, but that made me feel good. This means that ACIS is working properly :)
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
I was wrong in my post saying that it happened in first gear; I tested it out when I was running errands earlier, and it happens in all gears except first. If I were to have it at 50% throttle, then slowly increase to about 75% throttle, it accelerates sort of slowly at first and then hits the strongest after 3000.
ma70.ent: I will try to have a video up by about 10:30 (central time).
I apologize that my posts were confusing, I tried to word them as best I could, but it didn't seem to make a difference.
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
Setheroo;1238415 said:
I never see a need to take my NA past 5800 rpms. It is pretty much poop after that and I am wasting my time to not be hitting my next gear.
It's not up to me when to shift, it's up to the ecu. My car is auto.
benchwarmer
Straight Cougar
Aug 2, 2007
510
Lancaster, CA
I'd say I get best performance between 4500 and 6200 RPM. It pulls pretty strong up to 6800 but there is definitely a drop in power before I reach the stock redline.
Chambers
Now you know
Sep 9, 2007
983
Baltimore County, Maryland
NA autos are weird, a good friend of mine has one and it feels like it pulls harder than my five speed after putting the pedal down on a 20mph roll, but then when you put the pedal down at 45-50mph it will fall in feeling, until the lower gear grabs, and it doesn't quite feel like it pulls like my five speed, granted I didn't get a chance to drive it for long so it may have just been me not used to it.
In my car, I think it pulls all the way up to around 6,000-6,250 rpms. It doesn't feel like it drops off much at all, but the ACIS helps a lot.
"Torque Converter" is a hint ;)
