what do i do now. my mechanic just teold me that what i thought was a valve tap is now a piston slap...wtf do i do now.
gaboonviper85;1468021 said:Is this a fresh rebuild and if so what pistons are you running? Does the noise go away once the engine is warm! I'm not a fan of mechanics as most don't know what they are talking about.
7mLove;1468347 said:nope bone stock motor never rebilt 115,xxx miles on the thing and it doesnt go away when warm just gets a little quiter...i guess its time for a rebuild this summer i beams ct26-57 and low comprssion pistons...20psi anyone?
gaboonviper85;1468455 said:I can't see a stock motor getting piston slap out the blue....maybe it happens but I just don't see it.
grimreaper;1468387 said:If its really piston slap, it *should* go away when fully warmed. Adjuster had issues with coated pistons at non coated piston clearances though...
SideWinderGX;1468553 said:+1, especially piston slap that doesn't go away when the car is warmed up. That went from perfectly fine really bad in a short amount of time.
whitemike;1468730 said:Great advice, I don't see any response topping that one, might as well say thanks and close the thread. (not sarcastic)
7mLove;1468743 said:ill get a video if you want.
Supracentral;1468602 said:Please read this thread:
http://www.supramania.com/forums/showthread.php?t=20486
It will tell you everything you need to know to truly diagnose the issue.
You can not diagnose engine noises by just standing by the car and listening to it... Anyone who tells you they can doesn't know what they don't know. You need two trained ears and a mechanics stethoscope to truly find it. Either that or tear it down and mic everything...
Supracentral;1468763 said:
whitemike;1468765 said:It's ok, your job is done, let him do what he wants from here, the info is there. If he can't use it correctly, It's nobody's fault but his own, obviously.
7mLove: Did you read what he wrote at all? He clearly wrote, just listening to the problem CANNOT diagnose it. I can't put a stethoscope to my pc speakers, so you're going to have to find someone locally who knows what they're doing.
7mLove;1468990 said:Mike "Nightmare" Donohue
thats funny cause we share a last name...and my dad is mike hahaha
