My Torqueless wonder makes it to the dyno today
I
itr206
Guest
When did I say I was on pump gas?
I had a few gallons of 94 and put 2 gallons of C16 in just in case.
Its not a GT35R. Its a 61mm. Basically a PT61, Same shit. I believe its a 76mm wheel? Its the same shit every other person with an SP61, PT61, Big Kahuna, GT40 whatever you wanna call it runs.
WeDgE
Buh-bye 7M...
Jan 2, 2006
495
Alberta
You didn't, that's why I asked. :)
Specifics man, specifics. :D
blackout_89t
King of the roll
Apr 25, 2005
488
Toronto
58mm inducer, 82mm exducer, 50trim
77.5mm turbine
That is a gt40-82, that should be the comp. wheel you have, but not the same turbine.
That said, those numbers make me a little sad, hopefully with some tuning I can pull off 500whp on pump gas. (22-ish psi)
I
itr206
Guest
those numbers make me sad too, but you need to remember the rest of the set up. I am running only an SAFC on a stock computer. That allows me no timing control at all and the stock ecu has very little timing. Also the stock cams kinda suck for a single turbo. Cam gears make a difference too on the exhaust cam. trust me I know I should be making that power on like 20-22psi
It was my first dyno run since I put the car together. There is much more to come, trust me on that
blackout_89t
King of the roll
Apr 25, 2005
488
Toronto
keep us posted :naughty:
I
itr206
Guest
updated with the dyno sheets now.
Actually I wasnt too far off on thwe tq. I thought I might have exagerated, but i made 501 tq
