My Swap Project
Turbo Habanero
4,229
Tucson,AZ
As some of you know i was in a accident in my 87 Turbo on Nov 4th and i am in the process of swapping the motor and transmission into my 89 Turbo
So as of now i have both motors and transmissions out.
(Alitte info)87 is R154 the 89 was a Auto
My questions are
1. Motor Mounts i use post 89 Correct?
2. Where would you recommend finding a good Driveshaft? As the one from the 87 could be damaged.
3. I am using the oil cooler and intercooler off the 89 Will there be any problems?
4.Any other things that come with doing this kind of swap if would be super helpful if you could share the info even if it seems like i should know it.
Thank you all on Supramania for the help you have provided me in the past and in the future it has been much appreciated.
-Jordan
Merry Christmas everyone.
Turbo Habanero
4,229
Tucson,AZ
One more question comes to mind since i am putting a r154 in a auto besides the Start Switch what other electrical problems will i run into?
I am thinking mostly about the reverse lights and rear speed sensor or those types of connectors the same ?
Thanks again and any info/advice helps me out alot
