My supra on Anti-Lag :)
MDCmotorsports
Indy 500
www.MDCmotorsports.com
Ma70.Ent said:
Anti-lag, (Also called a Misfiring System or "Bang-bang" due to the popping sounds made when the system is active), is a system used mainly on WRC rally cars to eliminate turbo lag. It is a feature of the engine management system. WRC cars are fitted with a class mandated restrictor on the turbocharger inlet and this increases turbo lag significantly. Because of the pressure drop across the restriction, the pressure ratio for a given boost level is much higher and the turbocharger must spin a lot faster to produce the same boost as before.
Anti-lag effectively increases the mass of exhaust fed to the turbocharger. This is typically done by retarding spark timing to a point where most of the combustion happens in the exhaust manifold, typically around 40° ATDC. At the same time more air must be added, this can either be done by the use of a throttle bypass valve or a throttle stop solenoid. When anti-lag is switched on it is typically active when the throttle is closed, and when the throttle is opened the spark timing is resumed to normal.
Exhaust temperatures produced by this system are phenomenal but they can be controlled by varying the amount of fuel injected while anti lag is active; a richer mixture lowers the temperature. Anti-lag is typically only used on race cars because it can shorten the turbocharger service life down to impractical periods for street use. The turbine blade life is drastically reduced, and the entire exhaust system is put into shock, which can lead to explosion or fire. Rally cars generally change turbochargers every chance they get to do so.
-Wikipedia
Most people might have heard Misfiring System from Initial D though :p
Or just install an injector into the exhaust housing of the turbo. Spray when hot for best results.
Also, love the video but you really need a cage or some sort of seat support on those kirkey seats.
They will bend like butter in a wreck with no back support.
Tun_x
Built to do the NASTY!!
Utah
The car will be NHRA leagal by spring ... belly pan ... Driveline hoop .....roll cage ... Scatter sheild... longer lug studs. and so on..
Tun_x
Utah
boostadikt said:
jeez your engine bay is filthy.....how do you sleep at night;)
.... hurry and get your rear end together, i want a ride.
I gonna spend some time cleaning tonight ..as far as sleep I dont sleep much .
Tun_x
Utah
boostadikt said:
It shows:biglaugh:
I think I got most of the mess on the turbo side cleaned up ....this is the problem with a light gray engine bay ..you see everything.. hopefuly I can go to dans shop tonight and finish pressing my studs in. with any luck I should have it back together by the end of this weekend
