My supra on Anti-Lag :)
Ma70.Ent
1,871
NJ
Anti-lag, (Also called a Misfiring System or "Bang-bang" due to the popping sounds made when the system is active), is a system used mainly on WRC rally cars to eliminate turbo lag. It is a feature of the engine management system. WRC cars are fitted with a class mandated restrictor on the turbocharger inlet and this increases turbo lag significantly. Because of the pressure drop across the restriction, the pressure ratio for a given boost level is much higher and the turbocharger must spin a lot faster to produce the same boost as before.
Anti-lag effectively increases the mass of exhaust fed to the turbocharger. This is typically done by retarding spark timing to a point where most of the combustion happens in the exhaust manifold, typically around 40° ATDC. At the same time more air must be added, this can either be done by the use of a throttle bypass valve or a throttle stop solenoid. When anti-lag is switched on it is typically active when the throttle is closed, and when the throttle is opened the spark timing is resumed to normal.
Exhaust temperatures produced by this system are phenomenal but they can be controlled by varying the amount of fuel injected while anti lag is active; a richer mixture lowers the temperature. Anti-lag is typically only used on race cars because it can shorten the turbocharger service life down to impractical periods for street use. The turbine blade life is drastically reduced, and the entire exhaust system is put into shock, which can lead to explosion or fire. Rally cars generally change turbochargers every chance they get to do so.
-Wikipedia
Most people might have heard Misfiring System from Initial D though :p
Tun_x
Built to do the NASTY!!
Utah
I need to finish up pressing in the new Moroso lugstuds and go to the dyno before I cruise it.. My boss owns a Carrera GT. This will be my first victim.. I wil be shure to have video of that..
Can sombody please lighten up the video so you can actualy see somthing
supra90turbo
shaeff is FTMFW!
32
MA, 01440
11:1 cr?! you run racegas all the time or do you have a water/alky injection system to aid in keeping detonation down?
Tun_x
Utah
There is nothing but c16 in my veins..:evil2:
Tun_x
Utah
Reign_Maker said:
Tun X has a NASTY set up!
Tun, got any numbers off her yet?
No numbers yet.. I'm hoping for about 550 on low boost and over 800 on high boost/nitrous..The car will be competing in Las Vegas July 13-14 and Pomona in October..I cant remember the dates for Pomona off the top of my head. The car is extreemly light as well.... This factor sucks because I have to weigh so much for NHRA.....3750lbs if use the nitrous..
Tun_x
Utah
kwnate said:
Nice, I love the pic of your boy laying under there :)
not my boy ... I have 2 girls ..that is my best friends boy..he a real trooper
