History. Son Bought car and previous owner had converted it from Auto to Std. ( not pretty, god how I hate how many hacks there are out there. More on that later) Son was bringing car to Dad (certified car nut) (Calgary to Peace River) to freshen motor, clean up previous owners sins and install up grades. Had some speedy lube shop place in Calgary change his oil for him. Made it 4hrs from home and rattling in engine ensues. Smart kid shuts it down and phones dad. Got it shipped to my house (500km) . Dad takes apart. # 3 rod bearing completely gone. Piston was slapping cylinder head, Crank FUBAR. Piston pin clip from # 3 backed out and pin scrapping cylinder. Inspect block and some cylinders had water corrosion. Found out this not original motor but came from a wrecker. Decide on JDM motor. Got one in Calgary complete with turbo, alt, starter, transmission etc for $1166 cdn. Brought home from Calgary . Dad reassembles old engine just for parts and to keep altogether. Learned valuable lesson about bolt and parts tracking when it comes to these engines.
Son leaves for India for 6 weeks with vague instruction to Dad to go nuts and order whatever I needed to build engine. Silly boy.
Tore down JDM motor and pleasantly surprised. Lots of carbon in cylinders but other that that in excellent shape. For the hell of it I plastigauged the mains and they checked out a .002 to .003. I was pretty happy about that. Did the same with the cams and got the same result. Nice!
Planned upgrades. TO4E turbo Greedy boost timer and controller, 3” down pipe, BOV, Intercooler upgrade, I will custom make intercooler piping right up to throttle body.(I will also powder coat it for him. I have my own stuff) RC 550 fuel injectors with FPR and Walbro fuel pump. Light weight flywheel and upgraded clutch. Relocate oil filter and upgrade cooler.(building my own fitting on my lathe/milling machine) Aluminum rad with flexalite fans. APR Head studs with MHG. Greedy timing belt. 180 Deg Thermostat.. May go with the lexus AFM later. But will upgrade the intake to a K&N.
My son had a bunch of body mods he wants to do and paint the car but that is his gig.
Where I am at.
JDM motor tore down and inspected. Nice shape
Waiting on Rings and Bearings. Got head studs, and gaskets. Moroso wires and greedy timing belt
Blocked decked .006 to clean up corrosion pitting (plan on milling pistons .004 to ensure not interferences issues) Hand honed head and block to smooth finish. Slight hone on cylinder just to clean up. (no cylinder ridge at all) Waiting on warm weather to bring outside to clean, clean and clean the cylinder block.
Tore down cylinder head and did a mild port job on intakes and exhaust concentrating on eliminating short side radius ridges. Blended the bowls a little and smoothed up the runners. Grind valves and seats then lap them.( I have Sioux cylinder head grinding equipment) (told you I was a certified car nut ).
Install cams, lifters and valves and check for clearance. Instead of buying shims I will trim the valve stem to proper clearance (due to loss of clearance caused by grinding valve and seats) Most is .007 least is .003 that I have to take off valves. I will then shim the springs to bring them back to factory installed height due to the loss caused by grinding. I may even shim them an extra .010 for a tad more tension.
And this is where I am at.
Doing lots of reseach and got lots of ideas from the info I got from you guys at supermania. Great site. First time I ever joined a forum.
Searching for turbo, intercooler, fly wheel and clutch.
For now I am off to Molokai.:beer: Will check in when I get back.
If there is intrest in my thread I will continue to update.
Where I am at.
