My solution for mounting extra gauges.
Loki
The Future is Unwritten
Prince George, B.C.
Well since I really don't like a pillar pods and I already had 2 gauges on my steering column. I needed somewhere to put a few more. So I picked this up, and after finally getting to see it in person pictures do not do it justice. It was well worth the money I payed for it.
I'm going to be replacing all my stock gauges with aftermarket ones (maybe even the speedo and tach) and getting rid of the ones on the column, I'll also be adding an EGT, Oil temp, and Fuel pressure gauges.
Loki
Prince George, B.C.
upgradedsupra said:
Nice ;) So how will the gauges sit? Will the lip come off the gauges you choose to put in those slots?
Duane
The gauges will probably just sit inside the openings, unless I can find the gauges I want in a bigger size. As far as I know though they only make them in the smaller size.
I'll try and mock something up with it a bit later on and get some pics with gauges stuck in it.
Loki
Prince George, B.C.
I stuck in some of my Auto Meter guages I had laying around just so you can get an idea of how it will look.
I am not going to be using Auto Meter when it goes in the car.
williamb82
909
4
Tampa, Fl.
those are the same autometer z series gauges ill be using to build the new cluster in my mkii. however my boost, egt and wideband a/f gauges will be in a separate hood from a 4runner on the dash. cant wait to see this finished. what gauges will you be using?
supra90turbo
shaeff is FTMFW!
32
MA, 01440
hope you didn't pay too much for it... it's cracked you dumb canuck ;)
jk brayden. looks sweet. that's the same color my car's gonna be :D
Loki
Prince George, B.C.
I'm not completly sure on the guages yet, the ones I wanted to use would just slide in like how the Auto Meters are in the pic above. Now thinking about it I'm not sure I want it like that. I would rather have them so all you see are the faces of the gauges so it looks more stock.
tsuper92
supra addict
Apr 7, 2005
1,376
mass
i've seen that in person when matt had it.it's pretty cool,just cost alot of cash to fill it:)
Loki
Prince George, B.C.
foreverpsycotic said:
its a one off custom piece that someone created and doesnt want duplicated.
Yup, projectsupra made it and then sold it. Then that guy sold it to me.
Kurt, Defi doesn't make enough gauges to fll it up :( I'm not mix and matching gauges. I want all the gauges to be the same.
