My setup for the 89 (hows it sound?)
BJ91T
810
Baton Rouge LA
Well I made a thread a few weeks back but plans have changed and I now plan to do the JZ swap in the 89 shell that I have and keep my 91 stock for the daily drive. Well after looking into both aspects of the JZ series swaps I think I have decided on a 1.5JZ-GTE. I will do this in series first get a clip I assume and do a drop in swap to a 1jz-gte get the bugs worked out and get the car looking good. Drive the car for as long as it takes to source and build a 2jz-gte block. Once the 2jz block is done pull the 1jz and drop the block under the 1jz head (which will obviosly get some attention aswell) and run the car from a 1jz harness. When the 2jz block goes in so will AEM EMS and a 1jz-2jz jumper harness/adapter. Bassicly that (I assume) will give me a fun car and by fun I mean fast as all hell and make it quite simple and affordable (by affordable I mean i can buy new stuff at my leisure and not be rushed to get the car running. I have laid out my "end result" parts list keep in mind it will not all be done in any quickness since the car will run while the 2jz gets built. Tell me anything I may have left out or something I may not need. Along with a ballpark HP number if possible.
Big part of this list was based on HamsmkIII's brown car because I have loved that car since I joined the site.
2JZGTE Block
balanced crank
Crower Rods
Wiseco Pistons w/rings
ARP Main Studs
New Toyota Oil Pick up
New Toyota Oil Pump
1JZGTE Head
Ferrera 2JZ intake valves stock size
Ferrera 2JZ +1mm exhaust valves
Viton Valve Seals
Manley Valve Springs / Ti Retainers
HKS 1JZ 272 In/Ex Camshafts
HKS Cam Gears
HKS Timing Belt
Greddy Billet Catch Can
Toyota MHG
ARP Head Studs
Porting / Polishing
T4 tubular manifold
Precision GT70GTS w/ .84 hotside
HKS S/S 50mm Racing Wastegate
3" Turbo-back I will put a apexi N1 on the back
Blitz LM V-Spec Intercooler 4-Row w/ 3" Intercooler Pipes
HKS SSQV BOV (two of them??)
Dual Fuel Pump Hangar
Dual Walbro GSS341 fuel pumps
Dual -6 feed / - 6 return line
Aeromotive A1000 fuel pressure regulator with pressure gauge
MVP Motorsports - 8 dual feed / single return fuel rail
Siemens 950cc injectors
AEM EMS for the 2JZGTE
AEM AIT temp sensor
GM MAP sensor
AEM Boost control solenoid
HKS DLI-II
Greddy Gauges
AEM W/B
Koyo Racing radiator
FAL 210 dual electric fans
Samco Radiator Hoses
2JZGTE Water pump
R154 trans (so i will need 1jz FW and Bell 7m pp and disk)
ACT HD Pressure plate
6 Puck Ceramic Sprung Disc
C's Short Shifter
Braided Stainless clutch cable
Thats all I can think of for now
Thanks in advance
BJ Crifasi
Tim
regular member
Oct 16, 2006
272
CA
That is a really big list. It must be nice to have funds to back up that big list.:aigo:
OneJoeZee
Retired Post Whore
aboard the Argama
Why bother with a 1.5JZ?
You want the 3L so just get a 2J. Don't make things harder than they have to be. If you can't afford the 2J right out, then just wait a bit.
It doesn't sound like you're going to be finishing this car anytime soon, so just wait and get the engine you want the first time.
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
maybe its what he wants to do lay the fuck off guys jesus.
if he wants a 1.5JZ then let him be. damn all these people quick to bash someone and hound em....and who in the hell wants an auto tt mkiv? not me.
go on mustangman do what you want don't listen to these people i think its sweet and your car will be better then 90% of the people talking shit to you as you are building it man.....do the damn thang!!
BJ91T
810
Baton Rouge LA
thank you reaper yes its what i want to do, sure it will be alot of money but it wont hit me hard all at once because it will be a running 1jz car and i will slowly stockpile the parts for my 2jz bottom end. I dont see anyone bashing hams when he did his... And no i wont be getting a mkiv anytime soon
The Reaper
Jan 10, 2006
1,909
Florida
no problem man i feel ya slowly upgrading. instead of needing to take out a loan to build it LOL
i'm going 1.5JZ as well, wont be going AS big as you are for a LONG while but will be 1.5J with single 67 or 71 turbo by the end of the year is my plan
edit:: btw mkiv's are gay in the sense that they are 9-15 years old and are STILL over priced. a 94 TT 6speed should be around 12-15K not 25-30K thats horse shit
Ric
Setting the standard
Feb 22, 2007
1,432
Central Florida
www.1jzgte.us
What wiring nightmare? Just use a 1JZGTE harness and ECU on a JDM 2JZGTE. All you need is an SAFC2 with +18 across the board, and runs like stock.
Perfect til you go stand alone, single, bigger fuel, etc.
The Reaper
Jan 10, 2006
1,909
Florida
im gonna do a 1.5JZ still man if its what you want do it. if you want a 2J then do it.
before Ric was saying the head flow wasn't different and now he's saying it will be a restriction....makes no sense stick with one or the other.
im doing it to be different plus for me its cheaper. later down the line if i want to swap it out i will get a 2JZ head
Big Wang Bandit
You Can't Quit Me Baby
Feb 21, 2006
7,551
San Ramon, CA - 925!
The only reason people dont go FULL 2jz is A, They are cheap, B 2JZ-GTE heads are not cheap, and C, Modifications are required to run STOCK turbos on a 2jz-gte in an A70
So go single, go standalone, And you win
