I tried doing a search but I didn't come up with much.
Here are my problems in full.
I've already ran into a BHG, which I didn't have the know-how or the time to do it myself, so I had it replaced with HKS 1.2mm MHG, ARP Hardware.
My main problems still occuring are these;
1)In need of a new Throttle Position Sensor, had my friend test it and it came up with no response.
2)New Knock Sensor wiring
3)When I try to start my car, I can't just hop in my car and turn the key and have the ignition turn over. Say from going to sleep at night to waking up in the morning to go to work. When I do so, my car usually doesn't click, can take anywhere from a few tries to a minute or so. When I do get it going, it clicks a few times, then after that the engine finally turns over, but my problems don't end there. One the car does turnover, it is really boggy. Like it's dying to stay alive, and in order to keep the car from shutting off, I need to tap the gas pedal. Althought this doesn't happen after I've been driving my car around.
4)My car does idle extremely high, idles at about 1500-2000RPM. Any ideas on this?
5)Don't know if this is really an issue, more like an annoyance, but whenever I try to reverse, I get that grinding gear sound.
Anything else I need to fix at the moment isn't apparent. But I will update this thread so I don't create too many posts.
Also, I'm a pretty new owner of an mk3, purchased in January 08. As well, I'm new to SupraMania, and I've got to say this place has more info then I could've dreamed of :].
And any response to any of the above problems is much appreciated.
Thanks,
Dimitris
Thanks,
Dimitris
