crazysupra7mgte said:i'm going to replace the fuel pump, inj, i have a lexus afm. which wasn't in the car when i drove it. i had the timing at 10 degrees. the guy at napa said it was detonation. i was most likely running too lean and there the pistons went.
...wait a minute. maybe the lexus afm was in there. i put it in to test it out, make sure it works. i swore i took it out though right after cause i knew it wasn't a good idea to keep it in without the 550cc inj and AFPR. i'm not sure now... it might still be in there. i thought i put it in the glove box. i'm gonna have to chek now. that was 2 months ago. i don't remember. i'm gonna be so pissed if it's still in there. i know i put the stock one back in...
this would explain. I feel your pain on the kit a bunch of paper and aluminum for $500 when you get your kit make sure you do get EVERYTHING. when i got it they left out little things like oil pan gasket, oil filter mount gasket,ect. just little stuff. lucky I had a freshly rebulid engine to steal the oil filter gasket off of. anyway just make sure you got it all. there is alot of gaskets there and they don't always remember to put them all in there.
edit: btw where did you have the timing at before you ajusted it?
