thought i'd just put an update in this thread as the fidanza flywheel and 4 puc clutch has been put in. we found a lot of oily grime on back of engine behind flywheel, this was from leaking rocker cover gasket and probably a little from the crank seal .anyway all done and put about 300 miles on it. what you notice is a little juddering on start off but not enough to be anoying.
for the performance you Do notice faster acceleration through out the gear changes and when in top gear from 60mph much better than was.i'm not saying it wasnt quick enough just that you notice the difference.
post other exprience's from these type of upgrades
