Those of you that read my post of my no spark issue or check engine light issue and read how jetjock(god) told me exactly what my problem was(that I needed a new ecu...absolutely nothing else) and belittled me when I threw in another idea as seen here..
"Before you become dead to me what I told you *does* have to be the problem. While this may be rocket science to you it's near intuitively obvious for someone of my skill level. And did you think the TRSM being in agreement was some kind of ooga-booga? Your problem for me is equivalent to someone asking you why a tire is flat. One does not have to be God or even an angel which, as you're finding out, I'm not. What I am is not the one with a broken car.
I told you what it must be. I pointed you to the factory diagnostic path for the exact symptom and then followed up with a detailed explanation. What more did you want, your hand held? Not gonna happen. Nor should you go off on tangents. If you're unwilling to accept the advice of someone more knowledgeable (let alone the board's electrical/ECU SME and the service manual) then you shouldn't solicit it.
That's it, off with your head. Nice goin' Ace.... "
well he couldn't have been more wrong. the ecu sends out a 5 volt reference signal to the maf sensor, water temp sensor, and tps sensor. when that signal gets shorted out, it shuts down the computer. In my case it was the mass airflow sensor, I unplugged it and whaddya know I have spark and a check engine light.
I wasn't very impressed with the responses I was given, I was talked down for another suggestion about what it could be that I got from another toyota enthusiast and told no way could it be that. In the end he was right on. Then my thread was closed and he told me to go to another forum. I thought this forum was about helping other supra owners out with problems, boy was I wrong.
