Is that really a good idea?gaboonviper85;1203735 said:Hold rpms at 2300 and let it buck and act up long enough to throw a code....?
SUPERSNAIL;1203795 said:Is that really a good idea?
CajunKenny;1203803 said:Codes are your road map. One of three things may happen if you try this. 1. It'll throw a code and lead you in the right direction. 2. Whatever it is, will reveal itself by breaking completely. 3. Nothing.I think it's a good idea.
That being said, bend/flex/wiggle your CPS wires. Try to reposition them as much as possible. Don't be a tard and go pull on them like you're trying to start a lawnmower though! :biglaugh: We're just trying to locate one or more wires that may have a short/open in it. Use zipties if necessary to bundle them 'snuggly' (is that a word?) together or to hold them in a different position.
There may be a vibration at that particular rpm that causes your CPS wires to vibrate in just the right...or wrong way, causing your problem.
Good luck man!
CajunKenny;1203812 said:The CPS wires are a common intermittent problem with our cars. They are right above the exhaust manifold. It gets a wee bit warm there!![]()
supraman7mgte;1203816 said:yarg,that shield is there for a reason! I have an extra if you need one
jdub;1204911 said:The O2 will not cause this problem...A/F feedback goes into open loop during power enrichment (i.e. you go to WOT). It will cause crappy fuel mileage/poor emissions and needs to be fixed.
A bad O2 signal will not cause the ECU to enter fail safe or back-up mode.
When you checked for IC piping leaks, did you pressurize the piping and IC up to the TB?
I would also take a closer look at the CPS wiring.
