buckshotglass;1414131 said:Will this be ready for the meet in 10 days?
empera;1414570 said:thought 83mm was stock bore...and cometic made 84mm...
2mm more probably doesnt make a diff.
gaboonviper85;1414597 said:cometic makes a whole crapload of sizes but the 1.3mm with 84mm bore was $149 while the one I got was $117...
I consulted the search function and IJ about the bigger bore and from what I gather it's acceptable too run a larger bore gasket.
IJ.;1414621 said:I did however suggest my preference would have been a 2mm gasket with the correct size bore![]()
gaboonviper85;1414645 said:indeed you did....but I don't have adjustable cam gears and I'm not sure what lifting the head will do too cam timing as well as all the stock support brackets for the turbo and intake mounting...i personally would rather keep proper squish and compression on this motor as it's not gonna see big power:-(
Supraholics;1421642 said:Done yet? LOL...
kamikazemkiii;1422248 said:hows everythign comin along
gaboonviper85;1429573 said:I wish!
