well thanks for the reply. but it seems strange that all the issues he was having had to do with a clogged fuel pump sock.. but i could be wrong. i really wish he would chime in and reply himself. no offense..:icon_razzJustin727 said:steve had a clogged fuel pump sock. He changed fuel pump and fuel filter and problem was fixed!
atlpd3147 said:well thanks for the reply. but it seems strange that all the issues he was having had to do with a clogged fuel pump sock.. but i could be wrong. i really wish he would chime in and reply himself. no offense..:icon_razz
turbobob said:Wow, high praise indeed.
There is a new instruction manual posted on fullthrottle, check it out. It should make things a bit clearer. Any feedback is appreciated.
The rich limit and lean limit are %, not AFR. so you have yours adjusted for +/- 11% correction (roughly). So the Pro will add up to 11 % extra MAF signal, or remove up to 11% from its tune. A reasonable place to start, you may want to set the lean limit closer to 5% to limit how far the pro can lean out if the wideband sensor has a problem.
Great news,
Bob
