Figit090;1495291 said:IJ and Jetjock - so you're saying the head unit in the console with all the buttons, I will end up needing to replace that to get ANY heat soon? I haven't driven her in a while but I think I was getting mild heat, and pretty decent heat at 85, but its definitely not normal anymore. Plus the climate control "auto" mode was rather lackluster and didn't seem to truly warm things up like I would imagine. For example, say if I set it at 70...cabin temp is in the low 60's probably...it didn't do anything and it definitely wasn't 70 inside (engine was warm)...I had to turn it up to 72 or so to get it to start regulating temps.
What I understand is that the HVAC unit is the servo/motor unit that controlls cabin airflow, and the motors are controlled directly from the head unit (with all the buttons, like the stereo head unit I assume)??
I don't know what the amplifier is, or where it is.
Yes where the buttons are, there's an amplifier circuit inside that sometimes fails for whatever reason and as this controls the mixer door servo you can have a perfectly functioning heater tap and vsv but still have cold air, even cable tieing the heater tap doesn't fix it.
The 2nd Amplifier is for the AC and is the blue box above the dash but has nothing to do with Heat.
