I was originally going to make a "final" set up once i change my turbo to a t67 but these past few days its been really hot so i figure id make a quick cold air box and ic block off. So i thought id would be quick(took me about 6 hours THATS excluding making the template since i did that before.)
2 hours of that was learning HOW NOT to cut the acrylic Plastic :3d_frown: (broke the first ic BLOCK OFF)
I preaty much used all stock holes so i wouldnt need to make a new one.
AND as for the PS. it will be relocated OUTSIDE the box.
TOTAL COST: $43
would have been $5 less but my first IC block off crack when i was finishing the cut.
Note I painter the IC block off. and will paint the side walls of the cold airbox later.
anyways heres the picture.
gheto but hope it works and last "a bit" till i can make a metal one.
TOTAL COST: $43
