buldozr said:
Stock supra... not too shabby. I understand you are from California but, exhaust work is necessary. Cooleeze makes a decent downpipe and test pipe(to replace your stock cat) and bolt on your favorite cat back and you will love the results. Do a nice cone air filter(K&N, Apex'i...) and you will love it! Have fun.
Thanks for the tips. I have a list of a bunch of parts that i plan on dumping into my car. Im never gona get rid of this car so I plan on making this my full out racing car. Here's my list. Tell me if u have any different ideas or more ideas.
K&N Intake System
Blitz NUR-Spec Exhaust System
HKS Super Sequential Blow Off Valve
Random Technology 3 inch High Flow Catalytic Converter
Pacesetter Polished 1.5 inch Armor Coated Headers
Titan Motorsports Racing Head
ARP Head Studs
ARP Head Bolts
HKS GTII Wastegate
HKS 2mm Metal Head gasket
HKS Racing Bypass Valve
SVE 75mm Downpipe
HKS Intercooler Kit
SP 61GT Ball Bearing Turbo
SP Racing Brian Crower Stage 3 Camshafts
AEM True-Time Adjustable Cam Gears
Titan Motorsports Dual Spring Valve Springs
Titan Motorsports Titanium Retainer Set
JE .40 Oversized Forged Pistons
Japanese Performance Forged H Beam Direct Connecting Rods
Japanese Performance 90mm Veilside Style Throttle Body
Japanese Performance Turbo Exhaust Manifold
Walbro 255 L/Hr Intank Fuel Pump
Clevite Performance 7M Rod Bearings
Clevite Performance Main Bearing Set
Clevite Performance Thrust Washer Set
Titan Motorsports Billet Main Caps
GReddy 720cc Fuel Injectors
Flexalite Electric Cooling Fan
JIC Camber Kit
Unorthodox Racing Ultra Street Lightened Underdrive Crank Pulleys
Fluidyne Radiator System
GReddy Radiator Breather Tank
GReddy Timing Belts
Unorthodox Racing Ultra L Aluminum Flywheel
HKS Adjustable Fuel Pressure Regulator
HKS Fuel Cut Defencer
NGK Spark Plugs
NGK Spark Plud Wires
Eibach Pro-kit Lowering Kit
HKS Hypermax II Suspension Kit
GReddy Strut Tower Braces
Suspension Techniques Anti Sway Bar System
Stillen/Brembo Big brake Kit
Coilover Tein Type RA Damper Kit
SPEC Stage 5 Clutch Kit
GReddy Full Auto Turbo Timer
GReddy Profec B Spec II Boost Controller
GReddy Informeter
GReddy E-manage Engine Management System
