My FFIM...thoughts on it?
ZFast300Z
Trouble
Dec 15, 2007
102
Wisconsin
To the OP. What is the length of the manifold from the end of the number 6 runner to the end of the plenum? It looks like its terminating right at the number 6 port, and usually you want to extend the plenum past the last runner.
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
DavidBaustert;1216387 said:
I so much as figured that...as far as "parameters" I'm still not sure what you mean.
depending on what FEA program you are using, he might be refering to what kind of mesh you used. did you you a single pass or multipass adaptive (p-element). or he could just be refering to the flowrates, pressure, temp, stress/strain, etc
we use pro e and mostly analyze stress, strain and thermal distribution. ive never really analyzed flow.
92nsx
2,957
Clearwater, MN
schokomanu;1223084 said:
What about the shortrunner which allows AC to be kept?
Will you produce some more of it?
Ron will make what ever FFIM you would like for the right price :biglaugh:
DavidBaustert
Dayton Ohio
I just used the default parameters in Autodesk. STP @ 1 ATM. As far as the other stuff I'm not sure. I can check on that further if you're really interested.
DavidBaustert
Dayton Ohio
I believe its about 2.5 inches or so...the ports on the ends are also alot bigger.
