My Door Open Light Stays ON !!!!
Supra-Man18
357
miami
CyFi6;1201755 said:
http://www.youtube.com/watch?v=gMFLyCO5CD8
Maybe yo doors open mayn
Im sorry i had to...lol
LMAO.. na doors closed.. When i say i grounded the sensors off i mean i actaually disconnected the sensor and grounded the wires themselves off...( which is the actual action of that switch when the door closes they ground off and turn the light off ) and it didnt work.. i got different sensors and installed them and got the same result.. now i just plain give up..
Oct 11, 2005
3,819
20
Thousand Oaks, CA
You got that backwards. The switches are open circuit when the door is closed, and they ground the dome lamp wire when you open the door.
I would check those wires very carefully to see if they are pinched or rubbing anywhere near and inside the doors. If the insulation is worn away and the copper touches the car chassis, the light will stay on.
Supra-Man18
357
miami
Hey I also have this cel on my dash and i get code 14 out of it.. but the car runs fine.. the other guys with code 14 bog out or turn off..and i checked my coils and ignitor
Supra-Man18
357
miami
Guys sure enough the driver side wire was grounding out, it had a little kink in it and the rubber ripped..All lights off now =) except anti-lock and cel lol THANK YOU MUCH
