My 91 supra gets 10-12mpg...HELP
suprajjang
Supra Enthusiast
VA
the reason i dont drive the car hard is because of the bic ddp:icon_bigg once the wastegate starts opening, the cops seem to notice me alot more...lol dont need anymore exhaust tickets
squid699-if i had a vacuum leak, would the car still idle properly? Also would a vacuum leak cause a car to run rich?
thanks
edit: using the tsrm i went and checked all the vacuum lines and they are all in place and the hoses look good
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Vacuum hoses rarely cause enough of a leak to damage your mileage.
To give you a good example - the 3000 pipe to throttle body coupler. Mine was cracked - almost all the way around it. Leaking horribly. My idle was still fine, mileage was in the toilet, and I could still boost ~15psi. When I took this coupler off, it nearly fell into two pieces in my hands. Replaced it, and all of a sudden I boost faster, and my mileage went back to normal.
IHI-RHC7
"The Boss"
Oregon
depends on what the gauge reads for vac, but I sit around 17-19 units of vaccum at an idle. I really don't suspect a vac leak in this case because anyything post TB would yield a lean condition unless boosting...
suprajjang
Supra Enthusiast
VA
well i now have hardpipes from cooleeze on the way so hopefully this will solve the problem
