Little bit of an update. I got my HKS MAP sensor mounted. Need to plumb it in yet.. Not sure where to T off at.. any suggestions?
Also got a new spectre air filter.. I think it looks pretty nice. 40 bucks well spent in my opinion!
If you look at the bottom, you see where I mounted my EVC valve. Not sure if these things are water proof or not, which kinda worries me. But more than that, I believe the two big nipples go to the turbo and waste gate, and the small nipple is a MAP source. Not sure where I should tap this into either. There's not enough unused vacuum ports on these engines!!!
Also replaced my power steering feed line, which was leaking like a siv. No more leaks I hope!!!
And to top it all off, I did some maintenance to the DD. Only thing I'll have to do for 10k miles!
Just kidding it needs struts. Lol
