My 86 Supra
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
dont mind mike... hes trying to learn.
have you pulled codes yet to see if there is anything being thrown?
and i would double check you put all of the connections back on correctly.
after all that if nothing helps check physical timing and make sure your distributor is setup according to TSRM specs.
86SupraWrath
45
TX
Ok Rennat can u explain just a little bit more on the codes bc like mike im also tryning to learn :1zhelp:
