Thanks to evolution for the bottom end some months ago.
Some pics and stuff:
Check out my sweet ebrake knob. Yes that's a dead baby turtle. Let the hate begin.
And vid:
http://s187.photobucket.com/albums/x302/apxhero/?action=view¤t=cress-0.flv
Parts on car:
Jic flta2 for jzx81
Trd 2 way 4.3:1 in 4 bolt carrier
Spw type 4
Turtle brake
URAS rs exhaust
Weds sport sa70
R32 front brakes
SS brake lines
JDM polished door handles
81 MarkII trunk lock
4 point belts
New clutch pedal and hydros
Non abs brake lines
Equus 60mm boost gauge
Autometer street tach 3"
SAFCII black
HKS air filter
HKS turbo timer
29x12x3" FMIC
On order:
Kmac sways
Sparco seat
Sexy style aero
flipsidecustoms rear toe/camber arms
In shop:
Flex a lite heater
permacool fan (for sale!)
tourerV badge
Engine/mission:
JZX90/jzz30 wiring harness
ECU for said harness
rebuilt 2jzgte shortblock
resurfaced/valve seals 1jz TT head
machined 2jz cams
Non trac TB
USDM 550cc injectors
OEM 1jz gasket set
new 2jz oil pump
non hydrofan water pump
aluminum pulleys
ARP head studs
ARP flywheel bolts
DM tranny hardware
r154 trans rebuilt jza70 spec
HKS gd max clutch
HKS t4 turbo
T4 Chinamanifold
Tial 44mm WG
Still needed:
Driveshaft
Flipsidecustoms 6 point cage
SerialNine endlinks
SerialNine TC rods
Poly flca bushings
Poly rack bushings
And vid:
Parts on car:
Jic flta2 for jzx81
Spw type 4
Turtle brake
URAS rs exhaust
Weds sport sa70
R32 front brakes
SS brake lines
4 point belts
Non abs brake lines
SAFCII black
HKS air filter
HKS turbo timer
29x12x3" FMIC
On order:
Kmac sways
Sparco seat
Sexy style aero
In shop:
Flex a lite heater
tourerV badge
Engine/mission:
machined 2jz cams
Non trac TB
OEM 1jz gasket set
new 2jz oil pump
aluminum pulleys
ARP head studs
ARP flywheel bolts
DM tranny hardware
HKS gd max clutch
HKS t4 turbo
T4 Chinamanifold
Tial 44mm WG
Still needed:
Driveshaft
SerialNine endlinks
SerialNine TC rods
Poly flca bushings
Poly rack bushings
