Muffler Popping at Idle after tune-up
Apostle
88
Philly
Right after I changed my wires and plugs, I go to start my engine, which takes a few trys to start. And the engine doesnt sound the same, it also has a vibration like its dancing back and forth. The idle is also lower, gets ready to stall sometimes. There is also popping coming from the muffler even at idle. I'm starting to think it's running a cylinder short. I double checked to make sure I plugged all the wires in the correct ports in the coils, and they were fine. But I'll check again. Any suggestions?
supraman74
I bought it SUPPED up
Apr 26, 2007
89
Iowa
I never trust pre gapped plugs, always check them.
I got plugs that were pre gapped to far...
EDIT: What they said :icon_bigg
Apostle
88
Philly
Supracentral said:
Yea, check them anyway.
If the box got dropped, they are no longer "pre-gapped".
Makes sense since it came from UPS ground and traveled from Cali to PA, box must have been dropped atleast 10 times, lol. I will pull the plugs and check the gap. What should they be gapped at?
Edit: I checked all the wires for the forth time, they are all in the correct ports, still same symptoms and idling at 400-500.
Datsrboi
Loud pipes Save Lives
Jul 31, 2007
797
Haltom Texas
Plug the old wires up and see if it does the same?
Coil pack have to be ground? You mean ground to the head covers or are there wires that come from the packs? I havnt touch my supra in almost 2 weeks.
rakkasan
Currahee!!
Fort Campbell, KY
The coil pack has a ground wire too. Mine was broken & it had a miss. Replaced it & solved the problem.....
irocznissan
109
nj
same that little ground can cause u to chase ur tail for hours and make u start throwin parts at ur car.
Apostle
88
Philly
aha, there's the culprit. I damaged it while removing the coil packs. Can I buy the ground wire from the dealer or do I have to make my own.
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
Much much cheaper and easier to just make your own. I bet it just goes to the block somewhere, i could be wrong though.
Apostle
88
Philly
its like 4 inches long, i just dont know what gauge(thickness) it is. Not good with electrical stuff. But i'm sure its simple, I'll just make my own.
