I converted my AUTO to 5spd and wondered if the ECU's made any difference within a conversion. Im still currently using my AT ecu and it seems to work fine.
Devin LeBlanc;1701480 said:Im running a Auto harness in a Auto car with a 7MGT M/T ECU working fine, all functions of the ECT work
Devin LeBlanc;1702053 said:Maybe I got a ECU on crack..
I dont get it...hvyman;1703020 said:Its the transmission not the ecu. either ecu or trans have the same turbo and waste gate, The waste gate is what controls boost.
hvyman;1703025 said:What dont you get?
The waste gate controls the amount of boost the turbo will see.
All turbo models use the same turbo and waste gate.
The ecu has zero control. It can control how much fuel to add to air flow how ever,
The auto trans has more drive train lose and uses more energy.
Manual cars are always faster.
Contrary to common belief a manual car is faster in the 1/4 the only difference is the auto shifts fast mking it faster but the auto has to have more hp so actually the manual is more efficient.
lmao then itll have a clip of a stock supra gauge shooting up to the 8+ markWhosoever;1703016 said:Could switching the Geico really ad 2 lbs of boost?
