Due to a minor argument with the camera, here is another no-pics update.
Spent all day yesterday working on the car, got started at about 930am and went to roughly 630ishpm... Engine to tranny mount wings are on, all wiring is complete, oil cooler hooked up, IC piping hooked up, cold start injector apparatus hooked up... the car...is... pretty much done. Heh.
Now for the bit of blah. Filled it with oil and installed the battery and after double checking some things and getting some wiring straightened out, attempted to actually START the car tonight.... Nothing. Not a click. Not a turn over, nothing.:dunno: Not that I was actually expecting everything to fire up and run like a top, but still slightly annoying.
After jumping a wire to the starter, we actually got' the car to crank over; But still no firing. So, here's what I'm looking at: Bad connection of power wire to starter -easily fixed- and maybe a bad ground? Sean thinks that the lack of 3000 pipe IC couplers not actually being clamped is an issue as well. Along with air lines to the IAC.. makes sense. I'll try to get that all sorted out with in the next day or two and will also hopefully be able to post CLEAR pictures.
Off to bed.
