Motor won't separate from bellhousing!!! =(
PorterzSupra
703
Hebron CT
This is the first time I took out a motor with the tranny and bellhousing connected, I took out all the bellhousing bolts and I got it out like an inch but it wont dissconnect from the motor!! I have been pulling and prying on it for 3 hours, is there something im doing wrong?? Normally I would take out the bellhousing bolts and rock the engine hoist forward and back until the splines slide out , this is the first time im doing it like this PLEASE HELP =(
supra90turbo
shaeff is FTMFW!
32
MA, 01440
MDCmotorsports said:
Take out the clutch fork from the inspection plate.
Ditto times 1,000,000,000,000
The first time I pulled my engine, I knew about it and still forgot.
Do that. If you already have, grab onto the transmission and shake it like a baby. It'll come apart.
krazynutta
new zealand
Hey man is your car auto or manual if its auto have you unbolted the flywheel from the torque converter you do this from removing the black cover under the back side of the engine, there will be about 6 from memory bolts to undo.
chevyeater
wastegate hose is pulled
Long Island, NY
PorterzSupra said:
any suggestions for getting the flywheel bolts off without the engine turning over??
In order of preference:
1. Flywheel holding tool
2. Impact gun
3. Take off oil pan and wedge a block of wood against the crankshaft
4. Jam a screwdriver or something in the teeth of the flywheel
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
ive always used a crow bar to hold the flywheel by a tooth pressed against one of the nubs that stick out of the block as a leverage point and set the bottom of it on a jackstand.. watch your head...
here is a very quick pik of what im trying to say..
L
lanky189
Guest
ive never needed a tool for a flywheel, I just be sure to apply torque to my breaker bar so that i'm turning a circle thru the inside of the flywheel, basically make sure that when you're breaking the nuts loose the initial time, that the breaker bar handle is positsioned (sp and its early) over some of the other flywheel bolts
