Motor mounts
mcammarn
matt
Feb 24, 2012
668
olympia wa
So it was weird. When I pulled my engine on my 7mgte, the motor mounts just came right off. Both sides just fell. I'm asumming these were original mounts on my 89. So does anyone think they just broke bc there original? I never noticed any unusual vibrations before pulling motor. And then, what motor mounts should they be replaced with?oem or aftermarket? I plan on doing roughly 3-350hp
Just age and use. They're rubber so they can dry rot, and they can also be contaminated by oil pretty easily as well. I'm assuming you have the square style? Aftermarket is fine, but OEM generally lasts longer (much more expensive usually). There are upgraded ones too...
57trimMKIII
Texas Supras' Slowest
Jul 14, 2010
133
DFW, TX
Figured I'd share a few laughs in this thread (DISCLAIMER: These are old pictures). :icon_bigg
Here is my car shortly after purchasing it, you can clearly see that the passenger side engine mount is shot.
But instead of replacing it, why don't we go out and do some highway pulls? Yep, sounds like a great idea!
I managed to pop the engine up and out of the cup. Don't worry, here it is with new solid (urethane) mounts:
te72
Classifieds Moderator
6,618
9
WHYoming
Hey, it is trying to be a Dodge Slant 6! :p
OP, they tend to wear out for the reasons that Poodles mentioned. Nothing to really be concerned about, just replace them. :)
