morganson's COP S-Type setup
gsxr141
1,158
10
rochester
90 turbo targa . fresh stock rebuild. lex-550 combo. bic ddp, full 3" exhaust, apexi n1 muffler. driftmotion pulley kit, hard intercooler pipes. k&n filter. aasco lightened flywheel. greddy profec b spec 2 boost controller. holds 16lbs to redline. stock ct26....... for now. will be going upgraded turbo and megasquirt in the spring.
i'm in the market for an ignition upgrade. your setup sounds like it would be perfect. i can even have my tuner run it on the dyno to show before and after results.
Sparky33
75
NJ
interesting way of wiring it wouldnt it still be ok to just split the power 6 ways and the 3 signals 2 ways each? seems a little less complicated
morganson
274
Columbia, SC
Alright guys. No body get antsy on me. I am working on finalizing this thing and cleaning up the harness a little bit. Its going to take me a bit to get the parts rounded up for a second unit. When its done ill post up the finished products.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,239
Atlanta
To clarify- this is the DG528/FD496 coil, with shorter boot, rather than the DG500 or DG515, with the longer boot, correct?
morganson
274
Columbia, SC
It is, but due to the availability of the dg500 im going to try to use it on the next unit. The dg528 is just to narrow a production gap. Besides if i use the dg500 then you can use both the e260 and e261 (borg warner pn) straight plug vs angle plug but the bodies are the same. And both are easy to find through msd and accel. It just seems like a better coil solution if i can make it fit.
morganson
274
Columbia, SC
Could, but i already am cutting the boots to sit lower anyway so just cut the dg500 boot to length. Ill go into that when i finish the second unit. Measurments are a little different on the 500 vs the 528.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,239
Atlanta
Sounds good.
Couldn't find any source for connectors, but the one guy on Ebay.
Any idea where we could get black connectors?
morganson
274
Columbia, SC
So here is a question. Provided this thing proves itself on the dyno. Who here feels $200 shipped to your door is unreasonable? Or whould there be more interest in buying just the plate and the harness? No coils no hardware?
satx88supra
388
San Antonio
I'm interested. I was thinking $200 for the whole setup was fair. Do you think it'll handle 325-350hp easily? Not lookin for that break neck power but dyno results would be helpful if i ever decide to go BIG on the power.
Sent from my LG Optimus G
morganson
274
Columbia, SC
325 to 350 is a piece of cake for this setup. I suspect this will reach well into 20 to 25psi range if not more.
But dont worry guys i got one that will be going out to another member for unbiased dyno testing. No need to make any commitment just yet.
