actually,the percussion of the bass helps propel the car forward if that is the way it is faced. up to 20% better fuel economy can be achieved....nah,im pulling your chain now
Jeff Lange said:A point worth noting, even if you have a max lets say 2000 watt setup, you will almost never hit 2000 watts, and if you do, it will probably be for less than a few seconds at best.
Now typically you will be producing more than 12V, but lets assume 12V for arguments sake.
1HP = 745W (62A in a 12V system, not 25A -- not sure where 25A came from). So 2400W = 3.2hp.
3.2hp isn't that much, especially in a Supra. Of course that's assuming perfect transfer to electrical energy from mechanical (alternator), so it might be a bit higher, but still, not all that much IMO.
bigaaron said:Ok, now consider that the alternator is only about 50% efficent, so make that 3.2hp into 6.4hp. Then consider the pulley ratio, and our alternator pulley
is much smaller then the crank. Let's say it is 3 to 1, so make that 6.4hp into 19.2hp!
Jeff Lange said:Then consider that gearing doesn't change power (aside from losses), so it having a 3 to 1 ratio leaves it at 6.4hp.
Then there's still the fact that very rarely will you ever get even close to using all 2400W in a system rated for 2400W.
trucker said:y'all are of course assumong that the amp is a constant load..it isn't
transient peaks are drawn from battery, not the alternator as such, and alt re charges battery.
i've been out of the stereo game(last system i built was when hlcd's were all the rage)for a while,but the idle current for amps is very small, and you are only using a small percentage of that amps peak most of the time
that being said...i doubt that that amp is really anywhere near 1400 watts.
most of those numbers come from the marketing dept, not the lab
i imagine that amp would pale in comparison to something like an old school orion 225 hcca(btw i need four of these if anyone has one)
rated at 25 wats by 2 chanels it could run something like guarter ohm mono, real output like 800 into 2 4ohm dvc subs....and that setup would shake windows and set off alarms from a couple of blocks away. i doubt that this "1400" watt amp is even close in performance.
my vote is the weight has much more to do with fuel than electric drain ever could..
trucker said:ands anyway the point of the discussion was about how overrated the equipment is these days, and i think we both know i'm right on on that point...
