more than you ever wanted to know about wire
figgie
Twin Cities, Minnesot-ah
depends. spec55 is the low flourine version of Spec44 wire. Not important until the wire starts to outgas the flourine (ie fire) ;)
It is good wire though. And if the price is right.. why not. Fits the Autosport connectors that MoTeC uses like Spec 55.
some comparo
|Spec 55|Spec 44
Temperature|200c|150c
Material|X-EFTE|X-PVDF
Mil-spec|22759/32-35|81044
some comparo
|Spec 55|Spec 44
Temprature|200c|150c
Thanks Wayne!
I start the wiring next week.
(well sourcing and planning it all)
mk e
PA
Great thread.
I'll add this and maybe someone will tell me it's a bad idea, but I switched to a thermal stripper for tefzel wire 3-4 years ago and never looked back. It's very easy to use and no chance at all of a nicked wire.
kisedcd
27
Minneapolis/St Paul, MN
Very good write up, great to see all this information in one place.
As I am a GA avionics installer, I deal with alot of this on a daily basis.
One observation that I find interesting is that the contact color code also matches the resister color code.:icon_razz
Length of wire run comes into consideration for current carrying capability and whether or not it's in a conduit or free air. Wires lengths going into a car should'nt have to be so greatly scrutinized though since they are relatively short runs unless of course the wire is being pushed to it's limit.
Thanks again for spending the time on this great reference information.
airhead04
1,489
Lima, Ohio, United States
Hey figgie, would it be possible and maybe even beneficial to use one of those Autosport Connectors through the fire wall. Meaning where your harness sticks through the firewall, put a connector there?
sticky667
california
Figgie,
Resurrecting this old gem.
Any chance you can go over positioners needed for the DMC MH860 with Autosport/Deutsch connectors? I noticed you have 86-3/-4/-6/-7 on the first page.
Thanks in advance.
**edit**
guess I should've read the remarks in the autosport attachment. Info about how to select positioners for other types of connectors would be informative.
thanks!
mhemore
moses lake washington 98837
figgie;1092378 said:
This time.
Everyone has used the craptacular crimpers that they sell at NAPA, Autozone etc.
Well there is a crimper that is meant to do the job right and do it right the first time.
Tyco Electronics Pro-Crimper III for PIDG based terminal and butt-splices.
With this tool and the correct splices or terminal. The wire will break before the crimp lets go.
[thumb]http://www.supramania.com/forums/attachment.php?attachmentid=23468&d=1217471892[/thumb]
[thumb]http://www.supramania.com/forums/attachment.php?attachmentid=23469&d=1217471917[/thumb]
