Hello all, i searched the section for all the questions on cylinder wall to piston clearance with forged pistons and got a basic idea of the situation. More power means more heat which in turn means more expansion of the piston. My situation is i am doing a rebuild with .040" Probe forged pistons and i am trying to figure out a couple things. First of all, how do i know what cylinder to piston clearance i need for my power goals? I want to make a max of around 350 RWHP, but will probably be running around 12-13PSI of boost on the stock setup for a long time. Ideally, i would like to build the engine for a little less horsepower and keep it reliable and avoid as much slap as possible.
The guidelines for the Probes are about .015"-.045" clearance. Can anyone guide me in the right direction for what clearance i would need? Obviously i dont want to do damage by having the clearance too small, but i would also like to avoid slap, as the engine is not going to be making a lot of horsepower and reliability is key.
Second, i received my Probe pistons with rings from Driftmotion. They came with NPR rings. My question is what are the materials in the NPR rings, and what surface finish should i ask my machinist to put on the cylinder walls? I know that chrome rings are harder that cast etc and need a different surface finish for perfect and quick seating. Thanks for the help.
