well folks got the under tray. and yep didnt fit bec of my fmic. Its the hks style one. (like the old school style one) but Nothing Like cutting up $200 worth of plastic. I really hope this helps with the cooling.
hvyman;1927517 said:Stock fan clutch puts out over 3k cfm. 2200 is not even close.
hvyman;1928898 said:So is a 4 runner one.
1-2clutch-u;1929993 said:OK so the undertray didnt work so thats $200 gone.
1-2clutch-u;1929993 said:OK so the undertray didnt work so thats $200 gone. .
supraguy@aol;1930049 said:I just re-read this thread, and i didn't see it mentioned:
If you're using this car for the track, are you still running the ac system?
Road racing is a higher than normal heat load of course, and maybe it would help you to remove the ac condenser from the airflow path.
1-2clutch-u;1930289 said:Sorry for the lack of info. But no ac stuff up front or power steering cooler or even oil cooler to block flow. The oil cooler has been relocated to the driver fog light. Thanks jetjock well I think but I just wanted to know what other people have done. Someone has had to road race a 7m and ran into cooling issues? If they did a big rad then they would have ran into the not being able to run the stock fan. I dont really wanna throw money at it with out good results. Nick I did not do a cfm test. I understand that they did it for a reason but the end result of me replacing it didnt help me. So whats a fella to do. The days Iv ran so far the outside temp was about 65 max and track temp was 80 max so when It gets hotter out I'm sure it will be worse.
Poodles;1930475 said:- I know several people that have road raced 7M's and been perfectly fine with a stock cooling system.
