JustAnotherVictim
Nah, just need a new fitting for my cooler line.
Then allllllllll done. Until I get fancy relocation hoses.
91 mK3 said:nice job man. so ill be the first to drive your toyota 3000?
suprastanger507mgte said:Well...........getting pretty close here:
Got most of my stuff on Saturday to finish the project:
One Piece Steel Driveshaft from JawsGear - Man what a difference in weight this is compared to the stocker.
Wiring Harness and ECU -
Thanks Jeff @ Jawsgear
Harness - extended and ready for the car. Just need to splice in some power wires into fuse box etc.
XS Power Single turbo Manifold -
Lower Radiator Hose
Steel braided line to bypass Fuel dampner .
Thanks Ti @ Jawsgear
ISC Valve,
Throttle Cable bracket
Thanks Eric @ Jawsgear.....
I just need to order the fuel rail spacer from Toyota
Pick up T/4 / to T/3 adapter from ATP - They are 3 minutes away
Order the downpipe from Drewgo
My Camera battery died so no pictures.
OneJoeZee said:Wait...
What?
You're not gonna use the K26 setup anymore?
OneJoeZee said:Moe, what supporting mods will you be using with your K26 twins? Once your car is running and my car is running(more than 10psi), I'd like to compare and contrast with your 3L setup.
JustAnotherVictim said:Can I weld your pipes Moe?
suprastanger507mgte said:Seriously...you good at welding? lol
I'm getting there slowly..
jawsgear said:Guess who drove their car home today???:icon_bigg
HAHAHHAHHAsuprastanger507mgte said:lol... NICE~~~~ !!!! Sam told me about the little hiccup and some wrenches flying around in the shop.. lol :biglaugh:
jawsgear said:Nah, wasn't a wrench. It was a broken polished valve cover flying across the parking lot at about 8pm LOL. :icon_evil If you know any one that has an extra valve cover LMK. I need the intake side with the oil filler.
Jeff
suprastanger507mgte said:Mike G has a set Jeff. Contact him.......what a bummer though lol.
