Hey matt,
Just to sort of answer your oil in transmission on your Celica, assuming it is the 5sp, atf is actually recommended. My friend just filled his up with Redline D4+, he has a bad synco going into 2nd gear and it didn't fix it by any means but did help noticeably. As to the syncromesh you would want RP MaxATF, I hear it works well, but if I were you I would spend a little extra and get the redline expecially since you will only be changing it like every 20-40 thousand miles.
