More pics please? Maybe from the side?Dylan JZ;1656734 said:
Moy;1657011 said:a fender roller
I don't mean to be a smart ass, but seriously lol
jdmmk3;1657017 said:well ive heard people use a blow dryer and a metal bat too,
Dylan JZ;1656864 said:I posted some other pics in "the black supras thread" if you're interested.
btw, that car ^ looks fantastic.
Awesome! Def diggin it.89tMike;1624743 said:Paint & fender roll coming this month. What do you guy's think?![]()
Moy;1657018 said:well the RIGHT way is with a roller. Yes a heat gun or hair dryer should be used too. The heat warms the paint to a state where it becomes flexible, so that when you roll the fenders and create sharper edges, the paint doesn't crack and flake.
yes a baseball bat can be used, but it doesn't do the absolute best job. I've done fenders both ways, baseball bat was at a track on a drift car that needed clearance.
I've also used tin snips and just cut the "rolled" portion off and then used a sanding stone to grind down the edges so they aren't as sharp.
but using a fender roller is the best way to do it...
K_SHAN;1626231 said:find a new way home pizza boy...
They are Lenso D1R, rear are 18x10 +22, front is 18x9 +15. tyres in the pics are 245/40 on the front and 275/35 rear. i've since gone to a 235/40 on the front and will probably use a 265/35 at the back just to match it up. My fenders have been rolled, but I need to pull the fronts a bit more so that I can lower it another half inch.Blackdawg;1660332 said:what rims are those? size and offsets?
spiller;1660704 said:They are Lenso D1R, rear are 18x10 +22, front is 18x9 +15. tyres in the pics are 245/40 on the front and 275/35 rear. i've since gone to a 235/40 on the front and will probably use a 265/35 at the back just to match it up. My fenders have been rolled, but I need to pull the fronts a bit more so that I can lower it another half inch.
