Thats Supraad's car
ENGINE
Blueprinted, Re-bored block and skimmed, lightweight and balanced crankshaft,
Forged eagle H-beam connecting rods, ARP rod bolts, JE pro series forged pistons 0.40 oversize, JE plasma molly racing rings, ACL duraglide main and big end bearings, ARP main bearing bolts, 841 compression, 2mm multi layered steel head gasket, ARP head stud kit, ported and polished and gas flowed cylinder head, (skimmed, modified and custom head work), TRD 272 camshafts with 11mm lift, up rated valve springs and retainers, Piper cams under bucket shim kit, valves re-cut, AEM adjustable cam pulleys, Greedy timing belt, HKS iridium plugs, HKS oil cap, TRD high flow oil filter, NOS, wet nitrous oxide fogger system, coldfusion dual outlet purge valve, twin NOS 10lb bottles with twin bottle mounted gauges, NOS bottle heater, twin NOS racer safety blow off adapters and bottle valve blow down tubes, air con removed, repositioned alternator with custom brackets, custom throttle cable, polished valve covers and thermostat housing, block painted red
TURBO/INTERCOOLER
GT45 duel entry roller bearing turbo with steel internals and titanium shaft,
XS power stainless steel exhaust manifold with custom turbo and waste-gate flange, custom made 90mm straight through down pipe in 316 stainless steel, 100mm straight through exhaust system in 316 stainless steel, HKS high power muffler (for road use), XS power 50mm external waste-gate, custom 50mm stainless steel side exit screamer pipe, HKS super power flow 200mm air filter with 100m cold air feed, HKS suction funnel (race use), XS power 600x300x100 intercooler, NOS intercooler spray bar kit with custom spray bar, 75mm stainless intercooler pipe-work, HKS blow off valve, valeside style inlet plenum with custom made inlet manifold (ported and polished), 100mm throttle body, Koyo large capacity racing radiator, stainless still top and bottom hoses, Koyo radiator cap, twin 11in electric fans, Mocal 19 row oil cooler, Goodyear high performance oil lines, alloy catch tank with custom breather system, Mocal 10 row power steering cooler, Samco and braded hosing all round,
ELECTRONICS/FUEL
AEM stand alone, programmable engine management system with custom wiring loom, AEM 3.5 bar map sensor, AEM wideband lambda sensor with air/fule ratio gauge, HKS twin power ignition amplifier, Custom ignition coil conversion kit, Supra mk4 twin turbo coil packs, Varley Red top 60 racing battery, Apexi voltage charging stabilizer, fuse box repositioned, Apexi AVCR limited edition boost controller, HKS type-1 turbo timer, Auto gauge vacuum gauge, oil pressure gauge, fuel pressure gauge, Auto gauge 5in tachometer (rev counter and boost gauge, digital water temp, oil temp and air intake temp, volt warning light and shift light), pro exhaust gas temperature gauge, Alloy 12gallon baffled fuel tank (in boot), twin facet low pressure lift fuel pumps, large capacity alloy swirl pot, twin BOSH 044 fuel pumps, twin sytec high flow fuel filters, custom twin 10mm braided fuel lines and 10mm return, GRS Adjustable fuel pressure regulator with gauge, 850cc fuel injectors, polished fuel rail,
TRANSMISSION
Original automatic. Now, R154 supra five speed transmission (polished), XTD HT racing pressure plate, XTD six-puck copper ceramic racing clutch disc with sprung hub, XTD 11lbs pro-lite chrome-moly flywheel,
SUSPENSION
Koni adjustable suspension, Apex springs, front and rear strut braces, and Polyurethane bushes all round
BRAKES
Up-rated grooved front and rear discs, EBC red stuff pads (front) EBC black stuff (rear), Good ridge braded brake lines, racing 5.1 fluids,
WHEELS & TYRES
Luxor LD1 alloys with polished stainless still rims 8x18 front 9 1/2x18 rear,
225 / 40 ZR 18 front, 255 / 35 ZR 18 rear.
EXTERIOR
Standard mk3 super, engine bay repainted, custom front bumper (large opening for intercooler), vented head light covers, Aerocatch flush series bonnet pins, lightly tinted front and rear lights, under car painted silver
INTERIOR
Totally Stripped interior (rear seats, carpets, trim, lining removed) and boot, all sound deadening removed, repainted, OMP record 1 seats, LUKE 5 point 75mm harnesses, Italv sport leather steering wheel, sparco twin button kit, sparco aluminium pedal extensions, carbon fibre gear knob,
