MKIII aerodynamics question
LoveMySupra
96
Socal - USA
suprageezer;602282 said:
On the supra wings if you know anything about the aerodynamic shape of a wing, not talking spoilers here, that the Supra wing is nothing similar to aerodynamic, I believe it was nothing more than a trim piece. It has the same curve at the leading edge as it does on the trailing edge and in between is the same thickness from what I’ve seen.
I just noticed that the 88 wing, has a bigger hump on the front of the bottom and then curves up and gets slightly thinner toward the end. Like the bottom of a wing?.. anyhow.. Swapped the hatch and that's my observation.
destrux
1,183
10
PA
I think that when it comes to drag at high speeds, the low frontal area of our cars more than offsets the increase in cd compared to newer cars that have a huge frontal area (to reduce pedestrian injuries).
The nose in that picture isn't lifted up 2"... maybe 0.5". Still surprising though.
