mk4 brakes to mk3
Archon
67
Russia
www.200mph.ru
and one more..
This car (Toyota Aristo (Lexus GS300)) drives only in the city. NO off-road drive ever.
---------- Post added at 02:42 AM ---------- Previous post was at 02:40 AM ----------
PureDrifter
what rotors do you use?
I think I need 13" rotors. I don't know which are?
mytmk3
643
christchurch
Archon;1687076 said:
somebody can write me what is it "350z track rotors" ?
part-number or link, please
Thank you
Just a warning I have never personally tried using 350z rotors on a ma70 hub this is second hand information that I had read on one of these forums would hate for it not to work and have you say mytmk3 said they would
The Nissan Track rotors are a close enough match as you need to make new Hub rings even if you use the Mk4 Rotors, drama with the Mk4's is you need to turn down the Mk3 Hub 5mm so this means no ABS.
strictlySupra
157
Canada
is there a link to mkiv tt rear brakes on mkiii chassis?
lots of info on the procedure for the fronts, having a hard time finding a write up for the rears. thanks
shaeff
Kurt is FTMFW x2!!!!
10
Around
Old post, but since the thread was bumped anyway- yes, I posted a link to this exact writeup above.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
I've got them on my car. PM for more info if you want.
SideWinderGX
733
Archon, I PMed you but just in case you didn't get it or something, did you just throw a bracket together or did you draw up a diagram/schematic of where the bolt locations should be?
Interested in mounting up some LS400 rotors and calipers on my car (they fit in a 16" rim) and they share the same bolt locations as the MKIV caliper. Thanks!
