I was under the impression an LS400 caliper is the same as a JZA80 caliper....so yes you could, but there would be no difference.
joel903;1756700 said:Did the pad contact increase vertically with the different 13.5 rotors on this kit? Or no, and only more surface area is gained for the pads to ride on once brake is applied?
Also, does the pad contact the whole braking area on the rotor? No extra surface free riding and will start to rust right?
Lots of questions before I commit.
sethron71 said:Not sure what your first question is asking? But at this point it is more like you are questioning the quality of the kit, go to my Misc vendor page and take a look at the products I make to see the quality of my products. I don't produce products just for fun. They are all performance based, so as a whole to answer you questions the pad covers the entire rotor mating surface although there is pad over hang to the outside which is common with almost all systems. If you are unsure then wait till after the group buy is over and see the reviews and go from there!
Seth
3p141592654;1756962 said:What is the piston area, swept area and effective radius (torque radius)? Please compare to stock. Thanks.
Does the pad sit fully on the rotor?sethron71;1789091 said:Not sure where the information is conflicting. They are off the shelf rotors so you will be able to select what ever rotor you would like when you go to replace them! I will tell you now they will not fit under a 17" wheel. They only clear the inside of an 18" wheel by less than a half inch. The rotors are actually 13.1 inches. As for the picture the rotors are unused in the photo so there is no wear area on the rotor so it is just angle and lighting. There is only about a 1/4" of unused rotor which is typical. It puts the pads all the way out to the outer edge.
Seth
how do you round a 13.1" rotor to a 13.5" bbk!?sethron71;1789091 said:Not sure where the information is conflicting. They are off the shelf rotors so you will be able to select what ever rotor you would like when you go to replace them! I will tell you now they will not fit under a 17" wheel. They only clear the inside of an 18" wheel by less than a half inch. The rotors are actually 13.1 inches. As for the picture the rotors are unused in the photo so there is no wear area on the rotor so it is just angle and lighting. There is only about a 1/4" of unused rotor which is typical. It puts the pads all the way out to the outer edge.
Seth
