Ok, I've been fighting this issue since I bought this engine and I'm turning to the forum for more help because I've run out of ideas once again :3d_frown:. The car is a 2jzgte MK III supra. The title pretty much explains everything. When I start the car up it misses and wont even try to idle. Under load it starts missing at about 6psi and 4000 rpm. It runs fine in cruise (a/rs are a little rich but no missing). There aren't any engine codes. The A/R's on my wide band read around 13.0 in cruise and 11.0 under wot. Also I've attempted to determine which cylinder my engines missing on. It seems to be missing on all cylinders intermittently at idle.
Things I've tried replacing.
-Coils
-Ignitor
-New ECU (mines re tuned for higher boost, 7200 rev limit, no fuel cut)
-Several map sensors.
-Engines been rebuilt (450miles on new engine).
-Crank sensor
-Cam sensors
-2 different sets of plugs both copper core both gaped to .28
Mods:
Engine Rebuild
-Stock rebuild aside from upgraded arp head studs, arp rod bolts and acl race bearings.
USDM Cams
Master Power T70
12X24X3 1/2 inter cooler
3" exhaust
Mines ECU
and a lot of other stuff that wouldn't affect anything
here's my build thread if your curious
http://www.supramania.com/forums/showthread.php?94869-Newgen-s-2jzgte-Swap
My ideas on what it could still be:
-When I did my battery relocation kit I ran the negative to the bumper support and there's one ground on the engine plus my solid engine mounts (not sure if that would make a difference). I don't no if maybe I don't have a good enough of a engine ground. I plan on buying enough welding power wire tomorrow to make a permanent ground to the engine from the battery.
-The only other thing I can thing of is I extend my wiring harness longer then I should of. I believe I extended mine 26 inches instead of the typical 18 inches. Could there be enough of a signal drop off from the ecu to the ignitor or the coils or even for that matter the cam angle sensors or crank sensor that they may not be firing on time or the timing may be off?
Any ideas would be excellent. I've run out of ideas
-Coils
-Ignitor
-Crank sensor
-Cam sensors
Mods:
Engine Rebuild
USDM Cams
Master Power T70
3" exhaust
Mines ECU
